Product Name:Titanium Blade 40kHz Rubber Cutting Process Ultrasonic Tire Cutter Machine
Ultrasonic rubber cutting principle is through the ultrasonic generator 50 / 60Hz current into 20,30 or 40kHz power. The converted high frequency electrical energy is again converted into mechanical vibrations of the same frequency by means of transducers, which are then transmitted to the cutter through a set of amplitude modulator means which can vary the amplitude. The cutter transmits the received vibration energy to the cutting surface of the workpiece to be cut, in which the vibration energy is cut by activating the molecular energy of the rubber and opening the molecular chain.
Price:10.00
Hangzhou Altrasonic technology Co.,Ltd
Address:ZhejiangZhejiangHangzhouFuyangRoom 1101, Building 1#, No 398 Kowloon Avenue, Yinhu Street, Fuchun Silicon Valley, Fuyang, Hangzhou, Zhejiang, China
Descption:Hangzhou Altrasonic Technology Co., Ltd located in Hangzhou, China, was found in the 1990s, and is a subsidiary of Sunrise Group, a largest trading and manufacturing company in Hangzhou, China. Altrasonic has many years'experiences in the business of industrial ultrasonic components and ultrasonic devices in China. We use this experience and experise to provide only the best ultrasonic devices and components based on the competitive price.
Altrasonic equipment focused on the r&d of high power ultrasound applications, Altrasonic has absolute leading core technology, the most stable and mature manufacturing technology, rich experience, can provide direct ultrasonic application scheme demonstrate, structure design, system configuration and related parts production.
Altrasonic equipment cooperated with the key graphene manufacturers, applied the ultrasound equipment in graphene preparation process of industrialization firstly, and make the ultrasonic be a good supporting to the large-scale preparation of the high quality and low cost graphene materials.
Registered Capital:500000
EmployeeNum:8
Contact:LV
Telphone:86-571-88638953-0
Fax:86-571-88635972-0
Email:altrasonic@aliyun.com
