MAGIX Sound Forge Pro.11.0 Build 338 Portable
Sound Forge Pro is the application of choice for a generation of creative and prolific artists, producers, and editors. Record audio quickly on a rock-solid platform, address sophisticated audio processing tasks with surgical precision, and render top-notch master files with ease. New features include one-touch recording, metering for the new critical standards, more repair and restoration tools, and exclusive round-trip interoperability with SpectraLayers Pro. Taken together, these enhancements make this edition of Sound Forge Pro the deepest and most advanced audio editing platform available.
Recording
Record multichannel audio in ultra high quality. The redesigned recording dialog make for even more efficient workflows.
Sound Design
Select from thousands of included samples and create unique sounds for your productions.
Post Production
Professional mastering and processing tools help you edit audio and video files with ease.
Highly professional
Sound Forge comes with a holistic range of tools for sound design and editing. In addition to the classical set of recording features, the included tools deliver pristine quality in sound design, restoration and mastering use cases. Edit, convert and finalize in nearly every format with ease. And of course, every step can also be applied on objects.
Gold standard
Sound Forge assists you from importing media to finishing your masterpiece. Create Red Book compatible DAO CD masterings and prepare your project for replication.
Art and craft
The professional mastering tools by iZotope enable you to create both technical and creative masterings within Sound Forge. This makes it a true one stop solution for recording and editing audio.
NOTE: This portable release supported Win7, Win8/8.1, Win10 (both 32-bit and 64-bit)
