MAGIX SOUND FORGE Audio Cleaning Lab 24.0.0.8 + Cracked
MAGIX SOUND FORGE Audio Cleaning Lab 24.0.0.8 + Cracked | 400.39 MB
Information:
SOUND FORGE Audio Cleaning Lab 2 The easiest way to clean and restore audio. It's never been this easy to digitize, clean and restore your audio: SOUND FORGE Audio Cleaning Lab 2 is the perfect tool for enhancing audio from records, tapes, recordings and audio files. Hundreds of presents, smart 1-click solutions and intuitive controls make it possible. With its expansive selection of features and tools, this digital "Swiss Army knife" � now in its second generation � is a must-have for any audio enthusiast's toolbox.
The professional solution for cleaning and restoration
- Digitization, cleaning & restoration
- 64-bit technology & VST3 interface
- 8 audio tracks
- NEW! Audio cleaning with iZotope RX 7 Elements
- NEW! Mastering with iZotope Ozone 9 Elements
- NEW! WaveColor
Digitization
Easily transfer audio from analog media such as records and tapes to your PC.
Cleaning & restoration
Remove crackling and noise from records, reduce clipping and optimize speech recordings.
Quick & easy
The clear interface enables an intuitive workflow. A wide range of presets and program wizards are available to help with all aspects of using the software.
Record sound from tapes and records
A few clicks is all it takes to transfer individual songs and entire albums from records and tapes to your PC. Record spoken language in studio quality for podcasts (up to 96 kHz/24-bit resolution)
Import sound from CDs and videos
Quickly and easily import CDs onto your computer and automatically grab title info and CD covers from the web for original CDs. Starting editing the sound in your video files right after you import them.
Export
Once you've got the audio from your records, tapes or CDs on your PC, you can easily export it in any standard format, including MP3, WAV, OGG and FLAC.
Sound you can see: Spectral Cleaning
Spectral display lets you see the sound in your videos by generating a visual representation of all the different frequencies so you can quickly identify noise and remove it.
Automatic cleaning
The Auto Cleaning feature handles most of the cleaning work for you. It automatically scans and analyzes your audio material, and suggest a range of optimization settings you can use to enhance the sound in your video.
Optimize video sound
Perfect, noise-free video sound in a few easy steps � thanks to a wide range of presets and the video sound optimizer. A single click is all it takes to apply exactly the settings you need to enhance the music and spoken parts in your videos.
Program wizards & presets
Automatic cleaning and sound characteristics with a single click: Let the program wizards and over 360 presets help you get the most out of your material.
Tips & tricks
Toss out the user's manual: the Infobox provides valuable tips and tricks for all aspects of the program, helping you get the answers you need, when you need them.
Simple search
One keyword is all you need to find the templates, help articles, tools and effects you're looking for � thanks to the program's sophisticated search feature.
- Windows 10, Windows 8, Windows 7
- Processor: 1 GHz
- RAM: 2 GB
- Graphics card: Onboard, minimum resolution 1024 x 768
- Hard drive space: 1 GB for program installation
- Sound card: Onboard Onboard
- Optical drive: DVD
- Optional: CD/DVD burner
- Program languages: English, Deutsch
DOWNLOAD LINKS :
https://rapidgator.net/file/e6e751abae6188033d6e88ed6f82ec0e/Meera169_S.FORGE.Audio.Cleaning.Lab.24.0.0.8.rar.html
https://uploadgig.com/file/download/171c2b96418871eA/Meera169_S.FORGE.Audio.Cleaning.Lab.24.0.0.8.rar
https://nitroflare.com/view/66503E8517CCF0C/Meera169_S.FORGE.Audio.Cleaning.Lab.24.0.0.8.rar
