Advanced System Repair Pro 1.8.0.5
Advanced System Repair Pro brings you all the tools you need in one program to clean, fix, protect, optimize and boost your PC!
Fix your PC problems
Our multi-scan feature will give you easy to read and simple results. Our software will intelligently scan and anallyze your computer in minutes and give you complete thorough organized, detailed results.
Speed up, tune up and protect your PC
Start with a free scan from Advanced System Repair. You'll immediately find out the root problems affecting your machine's performance.
1-Click Maintenance
All the tools to made simple and easy! It's like having a professional technician at the click of a mouse.
Put Draining Apps to Sleep
Disable background apps that are draining your system.
Malware Removal
Finds and removes all types of harmful malware including trojans, worms, bots, adware, spyware, PUPs and more!
System Tweak/Optimizer
ASR will analyze your complete system and settings to adjust your PC to function at its maximum performance.
Junk Cleaner
Keeping your computer free from unnecessary clutter also helps make your computer last longer. Like any other machine, if you keep it clean and take care of it, it will serve you better longer!
Disk Defrag
With a simple 1-click, Advanced System Repair speeds up your PC by assembling fragmented files on your machine and organizing them more efficiently.
Privacy Cleaner
The all-in-one privacy suite to Clean Your Tracks & Protect Your Privacy! Make your computer safe, secure and more efficient!
Registry Cleaner
Over time your registry can become cluttered with errors and broken settings which lead to crashes. Advanced System Repair will clear out this clutter to make your PC more stable.
Operating System: Windows XP, 7, 8/8.1, 10
Home Page -
http://advancedsystemrepair.com
https://rapidgator.net/file/59f526fc50cb610e5c80865d681fa3dc/wwbl2.Advanced.System.Repair.Pro.1.8.0.5.rar.html
http://nitroflare.com/view/1F87A9322C3B936/wwbl2.Advanced.System.Repair.Pro.1.8.0.5.rar
