Belt Drive Balancing Machines14
Product Name:Belt Drive Balancing Machines
If you are looking for belt drive balancing machines with CE, ISO, SGS, and BV from professional supplier and with new technology, or if you are checking high-quality products made in China, new for rotors from China, or JP belt drive balancing machines, please feel free to contact JP Balancing Machine.Belt Drive Balancing Machines 1.Specially designed brackets transmit mechanical force with low vibration damping2.Durable and reliable sensor possesses good linearity3.Permanent calibration brings high accuracy with a permission of large initial unbalance amount4.Belt-driving offers higher precision and easier operation5.Advanced electrical measuring system and friendly man-machine interface6.Modular design offers a wide range of applicationApplicable to small workpieces?Technical data at a glancePHQ-1.6/5PHQ-1.6A/5APHQ-16AMax Mass of Workpiece(kg)1.6/51.6/516Max Diameter of Workpiece (mm)Φ300Φ300Φ300Distance Between Two Support Bearings (mm)15~50060~50060~500Journal Diameter Scope of Workpiece (mm)Φ 3~40(120°)Φ 3~40Φ 5~40Diameter Scope of Driving Belt (mm)Φ20~85Φ15~150Φ15~150Rotational Speed when the Diameter of Driving Belt is 100mm (r/min)?185,335,390,7001)~1470~1470Motor Power (kw)0.15DC0.23DC0.23DCMin Achievable Residual Unbalance Amount (emar)≤0.3g· mm/kg≤0.3g· mm/kg≤0.3g· mm/kg?Applicable to medium workpieces?Technical data at a glancePHQ-50PHQ-160HPHQ-300HPHQ-500HMax Mass of Workpiece(kg)50160300500Max Diameter of Workpiece (mm)Φ700Φ1000Φ1220Φ1500Distance Between Two Support Bearings (mm)80~700130~1270130~1270130~1270Journal Diameter Scope of Workpiece (mm)Φ 8~80Φ 15~753)Φ 15~753)Φ 15~753)Diameter Scope of Driving Belt (mm)Φ18~200Φmax400Φmax500Φmax600Rotational Speed when the Diameter of Driving Belt is 100mm (r/min)?700,10501)756,11761)756,11761)756,11761)Motor Power (kw)0.752)1.52)1.52)2.22)????Length of Bed (mm)?150015001500Min Achievable Residual Unbalance Amount (emar)≤0.5g· mm/kg≤0.5g· mm/kg≤0.5g· mm/kg≤0.5· mm/kg?Applicable to large workpieces?Technical data at a glancePHQ-1000HPHQ-2000HPHQ-3000HPHQ-5000Max Mass of Workpiece(kg)1000200030005000Max Diameter of Workpiece (mm)Φ1600Φ1800Φ2100Φ2400Distance Between Two Support Bearings (mm)160~1780160~2280160~2780160~3200Journal Diameter Scope of Workpiece (mm)Φ 25~1204)Φ25~1204)Φ25~1204)Φ25~1204)Diameter Scope of Driving Belt (mm)Φmax700Φmax800Φmax900Φ40~400Rotational Speed when the Diameter of Driving Belt is 100mm (r/min)?1330,19181)684,9861)921,13291)921,13291)Motor Power (kw)42)5.52)7.52)152)????Length of Bed (mm)2000250030003500Min Achievable Residual Unbalance Amount (emar)≤0.5g· mm/kg≤0.5g· mm/kg≤0.5g· mm/kg≤0.5· mm/kg1) Stepless speed regulation2) Frequency conversion3) Can add to 75-1804) Can add to 120-240
Price:10.00
Product Website:[Misafirler Kayýt Olmadan Link Göremezler Lütfen Kayýt Ýçin Týklayýn ! ]
Shanghai Jianping Dynamic Balancing Machine Manufacturing Co., Ltd
Address:ShanghaiShanghaiShanghaiBaoshanNo.2151.Pan Chuan Road.Baoshan Industrial Park.Shanghai.China.
Descption:Shanghai Jianping Dynamic Balancing Machine Manufacturing Co.,Ltd. is a professional manufacturer of dynamic balancing machine,which is high-tech technology enterprises of Optical-electro-mechanical Integration ,The high-tech business entity composed of scientific and technical personnel who have devoted to the design,development and manufacturing of balance machines for many years as well as the backbone elite with abundant experience.
Company sticks to a "Human Oriented" management pattern and attaches importance to the selection and cultivation of qualified employees. Every year, periodic or aperiodic professional trainings held at home and abroad make sure the employees have grasped the latest technology and skills. Outstanding expertise and employee quality guarantees high-quality products.What's more, good after-sale services and technical support eradicate your fear of trouble in the future when purchasing or using jianping balancing machine. Company has won AUDITED SUPPLIER by SGS-CSTC and passed ISO9001:2008 authentication of TUV,CE Certificate of Ente Certificazione Macchine
Quality is our fundamental, credibility is our aim, customer satisfaction is our eternal pursuit.Welcome visits,discussions and suggestions as well as inquiries from the new and old customers.Wish to establish a long-term partnership and friendship with clients all over the world
Registered Capital:100000000
EmployeeNum:300
Contact:Hong Ying
Telphone:86-021-39972151-0
Fax:86-021-39972969-0
Email:shjpdphj@aliyun.com
Company Website:[Misafirler Kayýt Olmadan Link Göremezler Lütfen Kayýt Ýçin Týklayýn ! ]
