Build Your Own GPS Tracking System Using Raspberry Pi Zero Wireless 2019
MP4 | Video: AVC 1280x720 | Audio: AAC 44KHz 2ch | Duration: 2 Hours | 1 GB
Genre: eLearning | Language: English
Design your own advanced data streaming and visualization tool to view the detailed tracking information of the moving vehicle
Develop a complete IoT-based GPS system to track the real-time movement of the vehicle in the web dashboard
Code in Python and extract the required information from the GPS module
Automate the GPSD to start on boot
Fetch raw data from the GPS module using Linux commands
Successfully test the GPS module in the Windows and Linux environments
Get to know the working principles of the Global Positioning System (GPS)
Set a static IP address in the latest Raspbian OS
Access the graphical user interface of the Raspberry Pi without using any external monitors
Install the latest operating system on Raspberry Pi Zero wireless without a monitor, keyboard, or mouse
Perform IP scanning and wirelessly access Raspberry Pi using Putty
Get to know the difference between Raspberry Pi Zero Wireless and Raspberry Pi 3
Get detailed knowledge about Raspberry Pi Zero Wireless and its previous versions
About
FAQ
1) I am new to Raspberry Pi, Can I do this course?
The course first teaches how to install and setup Raspberry Pi and then the projects start.
2) I have Raspberry Pi 3, can I do this course?
Of-course Yes!! The project can be completed on any version of Raspberry Pi.
3) What if I get stuck and need technical help?
Still have doubts, feel free to drop a mail at - [Misafirler Kayıt Olmadan Link Göremezler Lütfen Kayıt İçin Tıklayın ! ]
Learn to build a fully functional GPS tracking system from scratch. I have always been a firm believer in learning by doing and in this course, you will learn what you need to know by hands-on experience. You don't need any special knowledge except basic computer skills to get started with the course. Every one of you comes from a different background and hence; the course is crafted from basic to advanced level with minutely detailed in every video. The course is divided into 7 sections. Please note that the project covered in the course will work on any version of the Raspberry Pi. Only to keep the project development cost down and to embed the circuit anywhere we are primarily targeting Raspberry Pi Zero Wireless board.
At the end of the course, you will have a solid foundation on the navigation system. You will find it easy to build your own device from scratch. All the code and supporting files for this course are available at -
https://github.com/PacktPublishing/Build-Your-Own-GPS-Tracking-System-Using-Raspberry-Pi-Zero-Wireless-2019
https://rapidgator.net/file/b258ef8e6a3c1741bd206e1d3f02890e/v7q36.Build.Your.Own.GPS.Tracking.System.Using.Raspberry.Pi.Zero.Wireless.2019.part1.rar.html
https://rapidgator.net/file/6748b9606fa75a0a09b51df90521b83a/v7q36.Build.Your.Own.GPS.Tracking.System.Using.Raspberry.Pi.Zero.Wireless.2019.part2.rar.html
https://rapidgator.net/file/9bf17549a4baf0e112458b46279fe87f/v7q36.Build.Your.Own.GPS.Tracking.System.Using.Raspberry.Pi.Zero.Wireless.2019.part3.rar.html
https://rapidgator.net/file/4d391902e82cc126bb318ce6c01a8e13/v7q36.Build.Your.Own.GPS.Tracking.System.Using.Raspberry.Pi.Zero.Wireless.2019.part4.rar.html
http://nitroflare.com/view/3C17783361DB7AC/v7q36.Build.Your.Own.GPS.Tracking.System.Using.Raspberry.Pi.Zero.Wireless.2019.part1.rar
http://nitroflare.com/view/4DAC1C177343741/v7q36.Build.Your.Own.GPS.Tracking.System.Using.Raspberry.Pi.Zero.Wireless.2019.part2.rar
http://nitroflare.com/view/BF4F7DFC161EA1F/v7q36.Build.Your.Own.GPS.Tracking.System.Using.Raspberry.Pi.Zero.Wireless.2019.part3.rar
http://nitroflare.com/view/04FB41DFE759949/v7q36.Build.Your.Own.GPS.Tracking.System.Using.Raspberry.Pi.Zero.Wireless.2019.part4.rar
