Wise Registry Cleaner Pro 9.52.622 Multilingual
Wise Registry Cleaner Pro 9.52.622 Multilingual | 2.8 Mb
Wise Registry Cleaner is a powerful registry cleaner and registry optimizer. It speeds up your PC by cleaning your Windows Registry. Wise Registry Cleaner freebie does a neat job in cleaning out the Registry junk.
It scan your entire Windows Registry with only a few seconds by its advanced scanning algorithm. Wise Registry Cleaner will scan the Registry, flagging orphaned or bad Registry entries, and shows you the name and values for each.
Multi-user Cleaning Pro
This new feature is ideal for computers that are used by more than one person, such as home computers which are shared by a family and public computers in public places. People who have administrative rights can easily scan and clean all users' registry at once. You do not need to login under each individual account to scan & fix registry issues.
Fix Registry Problems and Boost Your PC Performance
The registry keeps growing when you use Windows, so does the obsolete items in the registry, which would eventually lead to performance degradation and even system crash. Wise Registry Cleaner scans the Windows registry and finds errors & residual items in the registry and then cleans or defrags them. By fixing these residual and corrupted items in Windows registry, your system will run faster and more stable.
The Practical Backup/Restore Feature
The registry is automatically backed up before any cleaning is performed. You can use it to restore the registry to the previous point, in case you encounter some system problem. You can also create a full registry backup or system backup manually with it at any time before making any major system or network configuration changes on your PC.
Scheduled Automatic Registry Cleaning
In the main interface, you can set Wise Registry Cleaner to clean the registry on a daily, weekly, or monthly schedule according to your own need. Wise Registry Cleaner will automatically clean up the registry in the background when the scheduled time is up. In settings, you can also create a 'Clean with 1-click' icon and place it on the desktop. With this feature, you can clean up the registry by just clicking the icon without opening Wise Registry Cleaner.
System Tune-up Optimizes System Settings for Better Performance
Other than cleaning up and defragging the windows registry, Wise Registry Cleaner can also optimize relevant system settings to improve both system speed and internet speed. After one-click optimization, you will see some improvement in your PC's performance.
Customizable Cleanup Options for Advanced Users
You can specify to run a normal, safe, or deep registry scan.
Custom areas of the registry can be scanned for things such as invalid file extensions, obsolete startup program entries, invalid software paths, and many more.
Exclusions are allowed, so you can tell Wise Registry Cleaner to avoid cleaning any registry items with specific words in them.
Windows XP, Vista, Win7/8/10 (both 32-bit and 64-bit)
https://uploadgig.com/file/download/A1079100039F60f9/k9knDmEX_Wise.Registry.Cleaner.Pro.9.52.622.rar
http://nitroflare.com/view/829C0BB32838C57/k9knDmEX_Wise.Registry.Cleaner.Pro.9.52.622.rar
https://rapidgator.net/file/2be0d6226cace7e1ebdad55eeb0837d3/k9knDmEX_Wise.Registry.Cleaner.Pro.9.52.622.rar.html
http://turbobit.net/illn6o28u22w/k9knDmEX_Wise.Registry.Cleaner.Pro.9.52.622.rar.html
