Virtual DJ Pro 7.4 Build 453 Final + Portable
[FN148] Virtual DJ Pro 7.4 Build 453 Final + Portable
No CRC ERRORS [RAR - 72.59MB + 10% recovery.]
WORKING & TESTED on Windows 8.1, Windows Se7en, Windows XP.
Atomix Virtual DJ is the MP3 mixing software that targets every DJ from bedroom DJs to professional superstars such as Carl Cox, and is used everyday by millions of DJs, and in many big clubs. It features a breakthrough BeatLock engine that will keep your songs in tune and let you work your mixes incredibly faster than any other DJ. The automatic seamless loop engine and the new synchronized sampler will let you perform astounding remixes on the fly. VirtualDJ is compatible with timecoded vinyls that let you scratch your MP3s directly on a real turntable, and with many other DJ equipment.
VirtualDJ will also let you mix and scratch music videos right from your turntables. You can use several interfaces to suit both beginners and professionals, record your mixes and burn them on CD, rip DVD, rip vinyl, create your own Internet radio, automatically mix playlists, use VST effects, display karaoke, and play DRMed file like Yahoo!
¤ Twin independent zero-latency players with:
¤ Standard controls (play, pause, stop, cue)
¤ Volume control
¤ Pitch control (from -34 to +34%)
¤ 3 band equalizers with Kill + gain
¤ One-click beat matching and synchronisation (new FAME algorithm)
¤ BeatLock engine: your songs will always stay in time, and you can work your mixes incredibly faster than any other DJ could
¤ Automatic beat-matched crossfading
¤ On-the-fly automatic BPM calculation
¤ Automatic pitch matching
¤ Automatic level matching
¤ Automatic beat matching
¤ Dynamic beat visualizer for easy "drag'n'drop" beat-matching
¤ Real scratch simulation
¤ Virtual scratch: Scratch your mp3 with your bare hand
¤ Automatic beat-aware LOOP function
¤ Synchronised sampler with 12 instant slots
¤ Master Tempo pitch algorithm
¤ Automatic first beat and last beat detection
¤ Automatic 4/4 phase detection
¤ OSC network synchronisation
¤ Infinite number of beatlocked desks (local multi-instance or network)
¤ Infinite number of cue points saved per songs
¤ Beat-aware effect plugins (included: beatgrid, flippin, vocal remover, filter, flanger, backspin, brake, etc...)
¤ VST effects compatibility
¤ Video mix with TV output (mix songs and/or video clips !)
¤ Full karaoke support
¤ Proprietary of FreeFrame video effects
¤ Inifite number of video effect simultaneously
¤ DJ-adapted video transition plugins
¤ Song database engine with easy-to-use search feature
¤ CoverFlow or text-only song browsing
¤ Compatible with iTunes playlists
¤ ID3 compatibility
¤ Automatic "filter" folders
¤ Automatic Hot-Swap of external harddrives
¤ Ready-to-burn file recording to burn your own mixed CDs
¤ Broadcast on the Internet
¤ CD to MP3 encoder
¤ Optional 3D sound card, 2 sound cards or Y-splitter for real-time monitoring or external mixtable use
¤ ASIO soundcard compatibility
¤ Fully customisable (skin engine and shortcut macro enngine)
¤ External MIDI keyboard compatibility for shortcuts
¤ Compatibility with most external controllers (DMC2, DAC3, iCDX, TotalControl, BCD2000, DJConsole, etc...)
¤ Optional automatic mixing: Virtual DJ recognizes the style of the music (techno, hip hop, lounge) and adapt its mix in consequence
Changes
new ContentUnlimited Video and Karaoke subscription plans
new improved LiveFeedback recommendations
Windows 8 multi-touch full compatibility
new actions "slip_mode", "slip", "loop_roll"
new actions "motorwheel 'speed'" and "motorwheel 'invspeed'" (for Denon motorized wheels)
midi definition <jog> can have ccmsb2="" for 21-bit messages
device definitions can include firmware update messages
fixed <slider orientation="circle"> with negative angles
fixed potential crash with malformed id3 tags
fixed transition applied to audio-only plugins on Mac
fixed potential crash when using clipbank plugin on Mac
fixed potential crash when using cover download dialog on Mac
System Requirements
MINIMUM system requirements:
Intel® Pentium® 4 or AMD Athlon™ XP
1024x768 resolution
DirectX compatible soundcard
512MB RAM
50MB free on the hard drive
RECOMENDED system requirements:
Intel® Core™ 2 or AMD Athlon™ X2
1280x1024 resolution
Multi-channel DirectX compatible soundcard
1024MB RAM
200MB free on the hard drive
Additional requirements for Video mixing:
2048MB (2GB) RAM
ATI™ or NVIDIA® video card w/256MB of Dedicated DDR3 RAM
Video card must support dual-screen output
Supported Operating System:
MINIMUM: Microsoft® Windows XP SP3 or newer
RECOMMENDED: Microsoft® Windows 7/8
Virtual DJ Pro 7.4 Build 453 Full
OTHERs
https://www.oboom.com/NWAXT1SC/FN048A1_DJ74453.rar
http://www.uploadable.ch/file/QJbpnPPMdVJ2/FN048A1_DJ74453.rar
http://uploaded.net/file/8nvnjhet/FN048A1_DJ74453.rar
http://rapidgator.net/file/c66bab693f991619c764ba8e2993be01/FN048A1_DJ74453.rar.html
SAFELINKING
https://safelinking.net/p/3f6134e781
Virtual DJ Pro 7.4 Build 453 Portable
OTHERs
https://www.oboom.com/6ZMZ4ZW0/FN048A2_DJ74453port.rar
http://uploaded.net/file/bg5dk0ae/FN048A2_DJ74453port.rar
http://www.uploadable.ch/file/gvqSRRfyY2Ve/FN048A2_DJ74453port.rar
http://rapidgator.net/file/e0c2948c73304230734b8db92528dea9/FN048A2_DJ74453port.rar.html
SAFELINKING
https://safelinking.net/p/8b6d8cfd71
