Veronisoft VS IP Monitor 1.6.5.1
Veronisoft VS IP Monitor 1.6.5.1 (x86/x64) | 2.6 Mb
VS IP Monitor is a software allows you to monitor the network connectivity of IP hosts on the Internet and LAN. The program periodically pings, checks TCP ports or HTTP on user specified IP devices (servers, routers, workstations). It is able to monitor IP addresses and show notifications when the status change. You can also view and access shared folders, open web and ftp, ping, trace route and sending messages. VS IP Monitor can generate status log files.
- Max. number of monitoring IP - 70 for one instance
- PING/TCP/HTTP monitoring
- Visual(Box Design, Message Box), Sound(Text To Speech,Custom WAV) notifications
- Executing custom application or BAT File on status change
- Logging options to txt file or csv status log
- Is able to run three VS IP Monitor instance on the same computer
Home Page -
http://veronisoft.hostei.com/
uploadgig_com:
http://uploadgig.com/file/download/B61a9f31159c3600/4up66.Veronisoft.VS.IP.Monitor.1.6.5.1.rar
http://rapidgator.net/file/be99b8c8fa18578c57325c4466a156d2/4up66.Veronisoft.VS.IP.Monitor.1.6.5.1.rar.html
http://nitroflare.com/view/1290D1915DF8CB7/4up66.Veronisoft.VS.IP.Monitor.1.6.5.1.rar
