Sorenson Squeeze Desktop Pro 11.1.0.34 Portable
Sorenson Squeeze Desktop Pro 11.1.0.34 Portable | 162.1 MB
Squeeze Desktop Pro is for the video professional. Apart from offering all of the great features found in Squeeze Desktop Standard, Pro offers support of the HEVC/x265 codec, the new standard in HD video.
Transcode into Avid DNxHD® (VC-3 Compliant Video Bitstreams) high quality, with Squeeze. Perfect for preparing media for Avid Media Composer, NewsCutter, and Symphony.
Squeeze Desktop Pro is for the video professional. Apart from offering all of the great features found in Squeeze Desktop Standard, Pro offers support of the HEVC/x265 codec, the new standard in HD video. Closed captioning insertion and pass-through supported, as are Apple ProRes and Avid DNxHD formats.
Avid DNxHD
HEVC/x265
Designed to double the data compression compared to prior standards at the same level of video quality. This means better video quality at lower bitrates.
Multi-Rate Bundle Encoding
Saves time by automatically packaging files for Apple HLS, Adobe Dynamic Streaming, Microsoft Smooth Streaming, MPEG DASH, and MP4 s by only encoding each data rate once and then packaging everything into multiple formats.
Closed Caption Insertion
Support for EIA-608 and CEA-708 closed captioning in source video and corresponding TTML output. Also closed caption pass-through.
Integrated Workflow
- Integration with Squeeze Server
- Seamless integration with AVID, Final Cut Pro, and Premiere Applications
- Multiple Watch Folders with multiple output options
- Direct integration with Squeeze Stream including 5GB Free Squeeze Stream Storage, Forever
- Universal device playback
- Publish to YouTube, AWS, Akamai, Limelight, FTP, and more
Pre Processing and Editing
- New manual timecode controls
- Trim in and out points
- Video cropping
- Duplicate Source
- DV Capture
- Standard NLE shortcut keys
Quality Filters
Audio Sync, 10 bit to 8 bit dithering. Black Restore, blur, brightness, contrast, crop, deinterlace, fade video, gamma, hue, saturation and lightness, inverse telecine, image orientation, RGB, Sharpen, Telecine 2:3 pulldown, Timecode, tint, video noise reduction, watermark, white balance, white restore, audio duration, audio mixer, audio pitch, audio volume, audio fade
* Microsoft(R) Windows(R) 8 and 10
* 1 gigahertz (GHz) or faster with support for PAE, NX, and SSE2
* 2 GB RAM or greater
* 200 MB available hard disk space
* QuickTime 7.2 or later
* DirectX 9.0b or later
https://uploadgig.com/file/download/a43137597d161de8/fHY8vzwt_Squeeze.Desktop.Pro.11.1.0.34.Port.rar
http://nitroflare.com/view/1A73B36DD554A0F/fHY8vzwt_Squeeze.Desktop.Pro.11.1.0.34.Port.rar
https://rapidgator.net/file/ae9c32f20c88c2f0a5892e23ef2490fc/fHY8vzwt_Squeeze.Desktop.Pro.11.1.0.34.Port.rar.html
http://turbobit.net/wz1msaxtpfdk/fHY8vzwt_Squeeze.Desktop.Pro.11.1.0.34.Port.rar.html
