Process Lasso Pro 8.9.8.40 Final + Portable
Process Lasso is a unique new technology that will, amongst other things, improve your PCs responsiveness and stability. Windows, by design, allows programs to monopolize your CPU without restraint - leading to freezes and hangs. Process Lassos ProBalance (Process Balance) technology intelligently adjusts the priority of running programs so that badly behaved or overly active processes wont interfere with your ability to use the computer!
* Dynamic balancing priority processes to optimize performance
* Using standard process priorities
* Acceleration in the foreground
* Limit the number of working copies of software
* Prevent run specific programs
* Maintain statistics of running processes
* Dynamic graph of system usage
* Separate core engine program
* Support for 32-bit and 64-bit systems
* And many more...
The functions of the GUI:
* Easy installation rules of priorities and process affinity to CPU default
* If desired, display tooltips to notify you at the time of an action
* Unique scoring system reactivity of the system and display graphics
* Easy to use menu system right click the mouse to quickly set priorities
* Monitoring and control processes without the need to open the GUI
http://rapidgator.net/file/cf8e9338e7fe88142d6adc458c47af2b/ju12r.Process.Lasso.Pro.8.9.8.40.Final..Portable.rar.html
http://nitroflare.com/view/9D8796957484435/ju12r.Process.Lasso.Pro.8.9.8.40.Final..Portable.rar
http://uploaded.net/file/8qis3i44/ju12r.Process.Lasso.Pro.8.9.8.40.Final..Portable.rar
