Mayjoy Automatic High Speed Facial Tissue Machine52
Product Name:Mayjoy Automatic High Speed Facial Tissue Machine
MJL-560 facial tissue machine
Introduction:
Automatic box-drawing facial tissue paper machine with embossing is to cut the base paper by knife roller shear, interaction fold into the chain of rectangle tissue.This machine adopts the vacuum adsorption, automatic folding counting function, high speed, folded neatly, easy operation, etc.
1.The machine adopts vacuum suction, automatic counting,with high speed, accurate number of advantages,is the advanced equipment of box drawing tissues paper production.
2.The machine is equipped with three tension adjustment devices,in order to ensure the dimensional accuracy of the finished folding.
3.The machine comes with fringe embossing and whole flower embossing of two kinds of flower embossing functions so that meet various customers’ production requirements.
4.This machine has automatic shutdown function once paper breaks, not only greatly reduce the wastage caused by paper breaks, but also to ensure the safety of the production process.
Machine Model JX—3L (560mm)
Product Size 180*200±2mm
This is China standard. Other size are available by adjusting the blade
Paper Diameter φ1100mm
Paper Core Inner Dia 76.2mm
Speed 0~100m /Min
Controller Electromagnetic speed
Embossing Device Steel to steel embossing
Embossing Roller End steel roller
Blank Lines Steel on steel , the independent regulator
Cutting System Pneumatic point cut
Vacuum System 7.5kw
Pneumatic System 3 air compressor ,at least the pressure 5kg/cm2Pa
Main Power 3kw
Dimension 5150*1400*1920mm
Weight 2200kg
Use of power Frequency Control , Electromagnetic speed
Price:8000.00
Zhengzhou Mayjoy Import & Export Co., Ltd.
Address:HenanHenanZhengzhouNongyeNo. 61 Nongye Road, Zhengzhou City, Henan Province, China
Descption:Mayjoy good quality and competitive price toilet paper rewinding machine, napkin machine, facial tissue machine, paper packing machine, automatic paper processing line by manufacturer since 1988
Registered Capital:50
EmployeeNum:7
Contact:RenDaniell
Telphone:86-371-55015029-0
Fax:86-371-55015029-0
Email:bestmayjoy@aliyun.com
