MAGIX Vegas Pro 14.0.0 Build 201 Multilingual
VEGAS Pro 14 is your project companion from start to finish. Edit professional video and audio material in high resolution formats up to 4K. Discover workflow-optimized plug-ins for image stabilization, design dynamic titles and create custom DVDs and Blu-ray Discs. Experience a new type of creative freedom with VEGAS Pro 14.
Easier. Better.
Give your creativity space to grow. VEGAS Pro 14 guides your video editing projects with its intelligent workflows and industry-leading audio editing tools, putting professional standards within easy reach. Native support for HEVC and ProRes file formats lets you place all common formats alongside one another on the timeline even video from RED cameras.
Amazingly efficient.
VEGAS Pro 14 gives you more editing power than ever before. With new velocity limits, you can create fast motion that 40 times faster than normal speed. New hover scrub capabilities make marking in and out points and adding footage from the Trimmer much faster and more efficient. That leaves more time for your main goal: creating impressive videos.
A solid foundation Image stabilization with proDAD Mercalli V4
Make shaky footage a thing of the past. Rescue material you thought was unusable and optimize it with proDAD Mercalli V4. Stabilize fisheye images or videos from your digital camera, action cam or 3D drone cam. The dynamic zoom-in function lets you create smooth, stabilized videos without impairing wide-angle shots.
Make a statement NewBlueFX Titler Pro Express
Create titles, captions and closing credits in broadcast quality with the NewBlueFX Titler tool in VEGAS Pro 14. Give your productions extra polish with sophisticated animated titles to brand your projects with your unique style.
Stylish NewBlueFX looks
Enhance the appearance of your footage with stunning video looks from NewBlueFX. Select from Film Color, Color Fixer Pro, Gradient Tint, Spotlight and Glow Pro.
Professional authoring
VEGAS Pro 14 supports you right from the import and through to the finished disc. The included VEGAS DVD Architect gives you full control from label design and menu controls to encoder settings.
Import Photoshop files with multiple layers to create custom keyframe compatible graphic animations and overlays. Comprehensive menu design and detailed encoder settings in VEGAS DVD Architect make it an indispensable tool for creating DVDs and Blu-ray Discs.
Highlights:
- Intuitive drag & drop workflow
- Smart tools for upscaling footage to 4K and Ultra High Definition
- Perfect image stabilization with proDAD Mercalli V4
- Titler Pro Express from NewBlueFX
- NewBlueFX Looks
- HEVC file support and native ProRes format support
- DVD and Blu-ray Disc Authoring with VEGAS DVD Architect
- High DPI Support
- High Frame Rate (HFR) support
- Operating system: Microsoft Windows 7 (64 bit), Windows 8 (64 bit) or Windows 10 (64 bit)
- Processor: 2 GHz (multicore or multiprocessor recommended for HD or stereoscopic 3D; 8 cores recommended for 4K)
- RAM: 4 GB RAM (8 GB recommended; 16 GB recommended for 4K)
- Hard drive space: 500 MB hard drive space for program installation; Solid-state disk (SSD) or high-speed multi disk RAID for 4K media
- Graphics card: Supported NVIDIA, AMD/ATI or Intel GPU with at least 512 MB of memory (1 GB recommended for 4K and GPU-accelerated video processing)
New in Version 14.0.0.201:
New features of this Update
Improved the Velocity envelope Set to functionality so that all points selected with the Envelope Selection tool will be set to the value entered for any of the other selected points
Added functionality for reading and saving project media tags to HEVC and ProRes media
Add new Velocity envelope presets (20% and 40%) to make working with high-frame-rate video easier
Greatly increased the number of scripts that can be shown in the Scripts menu
Added a general preference to allow users to enable legacy GPU rendering
Expanded the low-end range of the sharpen effect to allow access to softer values
Native support for reading ProRes 4444 files with full bit-depth
ProRes rendering capabilities including presets
Trimmer toolbar Add buttons and keyboard shortcuts now always honor the Trimmer in and out points
Hover scrub improvements have been made to support quantization, snapping, and showing selection
Support for reading HEVC hvc1 file variants
Bug Fixes
Resample mode now respects the Start all new projects with these settings checkbox in Project Properties
Loading multiple ProRes clips at the same time no longer crashes the application
Custom keyboard mapping for scripts now persists
Text that showed up badly cropped in the Titles & Text plug-in dialog box when running in Windows 7 now displays properly
Undoing a change to project properties frame rate no longer prevents the timeline cursor from functioning properly
Luminance values are now displayed properly for ProRes files
Plugged a memory leak that occurred when loading multiple AVCHD or HDV files (fixed in previous update)
Adjustments you make in the video event FX Curves panel are now saved properly
ProRes files rendered from VEGAS Pro now properly report interlacing and audio information
Removed a Render Alpha Channel checkbox that mistakenly appeared when rendering to a CineForm AVI file (which does not support an alpha channel)
Hit Film Express interoperability is now functioning properly
Media tags are now properly saved for Panasonic P2 files
The update process now works without crashing in all upgrade scenarios
VEGAS Pro no longer exhibits random crashes upon closing the application
Help topic for Working with HFR broken link has been repaired
VEGAS Pro no longer crashes when attempting to read ProRes HQ - 4096x2160-23.976p files
HDV/AVCHD file loading is no longer significantly slowed in VEGAS Pro 14 compared to previous versions
Quantize to Frame now work as expected when setting project video settings to match media, and project/clip frame rates differ
Wavehammer Surround demo beeps are now properly removed from registered product
The selection rectangle now shows up for each tool that includes a color picker.
Fixed stuttering/judder issues related to playback/rendering of certain HEVC/ProRes files
uploadgig_com:
http://uploadgig.com/file/download/45f46fa5aB374d5E/epqnf.MAGIX.Vegas.Pro.14.0.0.Build.201.Multilingual.rar
http://rapidgator.net/file/2d807172ef3ea6c11232c855ac364aee/epqnf.MAGIX.Vegas.Pro.14.0.0.Build.201.Multilingual.rar.html
http://rapidgator.net/file/f64a81b11a1cc0b647203300397616da/epqnf.MAGIX.Vegas.Pro.14.0.0.Build.201.Multilingual.rar.html
http://nitroflare.com/view/056A90E1354C8F7/epqnf.MAGIX.Vegas.Pro.14.0.0.Build.201.Multilingual.rar
