MAGIX Vegas Pro 14.0.0 Build 189 Multilingual
VEGAS Pro 14 is your project companion from start to finish. Edit professional video and audio material in high resolution formats up to 4K. Discover workflow-optimized plug-ins for image stabilization, design dynamic titles and create custom DVDs and Blu-ray Discs. Experience a new type of creative freedom with VEGAS Pro 14.
Easier. Better.
Give your creativity space to grow. VEGAS Pro 14 guides your video editing projects with its intelligent workflows and industry-leading audio editing tools, putting professional standards within easy reach. Native support for HEVC and ProRes file formats lets you place all common formats alongside one another on the timeline even video from RED cameras.
Amazingly efficient.
VEGAS Pro 14 gives you more editing power than ever before. With new velocity limits, you can create fast motion that 40 times faster than normal speed. New hover scrub capabilities make marking in and out points and adding footage from the Trimmer much faster and more efficient. That leaves more time for your main goal: creating impressive videos.
A solid foundation Image stabilization with proDAD Mercalli V4
Make shaky footage a thing of the past. Rescue material you thought was unusable and optimize it with proDAD Mercalli V4. Stabilize fisheye images or videos from your digital camera, action cam or 3D drone cam. The dynamic zoom-in function lets you create smooth, stabilized videos without impairing wide-angle shots.
Make a statement NewBlueFX Titler Pro Express
Create titles, captions and closing credits in broadcast quality with the NewBlueFX Titler tool in VEGAS Pro 14. Give your productions extra polish with sophisticated animated titles to brand your projects with your unique style.
Stylish NewBlueFX looks
Enhance the appearance of your footage with stunning video looks from NewBlueFX. Select from Film Color, Color Fixer Pro, Gradient Tint, Spotlight and Glow Pro.
Professional authoring
VEGAS Pro 14 supports you right from the import and through to the finished disc. The included VEGAS DVD Architect gives you full control from label design and menu controls to encoder settings.
Import Photoshop files with multiple layers to create custom keyframe compatible graphic animations and overlays. Comprehensive menu design and detailed encoder settings in VEGAS DVD Architect make it an indispensable tool for creating DVDs and Blu-ray Discs.
Highlights:
- Intuitive drag & drop workflow
- Smart tools for upscaling footage to 4K and Ultra High Definition
- Perfect image stabilization with proDAD Mercalli V4
- Titler Pro Express from NewBlueFX
- NewBlueFX Looks
- HEVC file support and native ProRes format support
- DVD and Blu-ray Disc Authoring with VEGAS DVD Architect
- High DPI Support
- High Frame Rate (HFR) support
- Operating system: Microsoft Windows 7 (64 bit), Windows 8 (64 bit) or Windows 10 (64 bit)
- Processor: 2 GHz (multicore or multiprocessor recommended for HD or stereoscopic 3D; 8 cores recommended for 4K)
- RAM: 4 GB RAM (8 GB recommended; 16 GB recommended for 4K)
- Hard drive space: 500 MB hard drive space for program installation; Solid-state disk (SSD) or high-speed multi disk RAID for 4K media
- Graphics card: Supported NVIDIA, AMD/ATI or Intel GPU with at least 512 MB of memory (1 GB recommended for 4K and GPU-accelerated video processing)
What's New in Version 14.0:
Hover scrub technology. Quickly scrub through footage in the Trimmer window and add In and Out points on the fly.
Upscale HD footage for use in 4K and UHD projects. Achieve breathtaking quality in every project. Smart Upscaling technology gives you the power to use your archived HD footage in your 4K productions.
RED camera support. Quickly and easily import and edit recordings made with the latest RED digital cameras into VEGAS Pro 14.
Up to 40x video velocity. Create extreme fast motion effects with the new higher velocity limit. Combine with the event playback rate for a maximum clip velocity of 40 times normal speed.
Smart zoom. Define the focal point of your video regardless of what was originally framed in camera. Use keyframing techniques to create exact zooms in post production that your videographer didn't shoot in the field.
Smart Adaptive Deinterlacing. Transform even the fastest paced deinterlaced material to modern progressive footage with stunning quality and clarity.
Script for grouping video and audio events. Create custom scripts for combining video and audio material. Automatically group objects you have selected.
You decide which resampling mode to use. Set resampling mode on a project-wide basis and start all your projects with that setting if you choose to.
uploadgig_com:
http://uploadgig.com/file/download/47af6CE49ed679bd/16nzo.MAGIX.Vegas.Pro.14.0.0.Build.189.Multilingual.rar
http://uploadgig.com/file/download/51D0096d9a8d11e0/16nzo.MAGIX.Vegas.Pro.14.0.0.Build.189.Multilingual.rar
http://rapidgator.net/file/2e042c775c99831e3c941984048e44e0/16nzo.MAGIX.Vegas.Pro.14.0.0.Build.189.Multilingual.rar.html
http://nitroflare.com/view/06962955B185E44/16nzo.MAGIX.Vegas.Pro.14.0.0.Build.189.Multilingual.rar
