Final Cut Pro X 10.3 Multilangual MacOSX
Completely redesigned from the ground up, Final Cut Pro adds extraordinary speed, quality, and flexibility to every part of the post-production workflow.
Revolutionary Video Editing
• Assemble clips in the Magnetic Timeline without clip collisions or sync problems
• Use Clip Connections to attach B-roll, sound effects, and music to the timeline
• Reduce clutter by grouping clips into a Compound Clip.
• Perfect your pacing right in the timeline with the Inline Precision Editor
• Cycle through different shots, graphics, or effects at one place in the timeline with Auditions
• Edit multi-camera projects with automatic sync and support for up to 64 camera angles
Powerful Media Organization
• Organize your work within libraries for efficient media management and collaboration
• Work natively with a broad range of formats including RED, AVCHD, H.264 from DSLRs, and more
• Content Auto-Analysis captures camera metadata and analyzes shots in the background
• Create and apply custom keywords on the fly as you select ranges in clips
• Smart Collections let you dynamically organize content and find any shot in a few clicks
Incredible Performance
• Final Cut Pro uses all the GPUs in your Mac for superior real-time playback performance and fast background rendering
• 64-bit architecture uses all the RAM in your system for larger projects and richer effects
• Background processing lets you keep working without interruption
• External monitoring lets you route video and audio through HDMI or third-party Thunderbolt and PCIe devices
Compelling, Customizable Effects
• Beautifully animated, easily customizable 2D and 3D titles
• Preview effects to see how they look with your footage before applying them
• Change the look of titles, transitions, and effects using intuitive controls
• Control effects with precision using a keyframe editor that appears directly in the timeline
• Use third-party FxPlug plug-ins with custom interfaces and dual-GPU support
Integrated Audio Editing
• Expand and edit multichannel audio files directly in the timeline
• Let Final Cut Pro repair significant audio problems such as hum, excessive noise, and more
• Sync DSLR video with separate audio in a single step, with instant audio waveform matching
Intuitive Color Grading
• Improve the look of any clip with the single-click Balance Color feature
• Apply the Match Color feature to match the looks of two clips shot under different conditions
• Manipulate color, saturation, and exposure with the Color Board
• Fine tune color for a specific color range or area of the screen using keying and masks
One-Step, Optimized Output
• Deliver projects for playback on Apple devices and websites such as Vimeo, YouTube, and Facebook
• Use themed menus to quickly author and burn a DVD or Blu-ray disc
• Export customized audio stems and multiple versions of a finished video using Roles metadata
• Import and export XML to support third-party workflows
What's New in Version 10.3
New Interface
• Redesigned dark interface puts the focus on your video
• Configure window layouts into custom workspaces for tasks like organizing and color grading
• Fill a second display with the timeline or hide the timeline completely
• Expand the Inspector to full-screen height
Magnetic Timeline 2
• Color coding of clips based on roles - such as dialogue, music, and effects - lets you understand your project at a glance
• Create, assign, and customize the colors of roles to identify different types of audio and video clips
• Enhanced Timeline Index lets you drag and drop audio roles to rearrange the layout of your timeline
• Focus button in the Timeline Index lets you highlight specific audio roles and collapse all others
• Show Audio Lanes button in the Timeline Index displays a structured timeline layout with dedicated spaces for each audio role
• Add audio effects and keyframe audio volume changes to an entire role within a Compound Clip
• iXML support enables automatic creation and assignment of roles based on metadata from an audio field recorder
• Create and manage a unique set of roles for each Final Cut Pro library
Wide Color
• Images are now viewable in wide color on supported Mac computers and external displays
• Import, edit, and deliver video in standard Rec. 601 and Rec. 709 color spaces, or in wide Rec. 2020 color space
• Configure color spaces for both libraries and projects
• Log footage from ARRI, Blackmagic Design, Canon, Panasonic, and Sony cameras, as well as RED RAW footage, can be manipulated in real time while preserving wider color
• Range check overlay in the viewer highlights areas out of the standard RGB range
• Video scopes display wide color in real time
Support for the Touch Bar on MacBook Pro
• Tap to execute common functions like volume control, fade in and out, and media import
• Easily access advanced editing commands, including Override Clip Connections, Trim to Start, and Trim to End
• View your entire project at a glance and navigate with touch in the timeline overview
More Video Formats
• MXF-wrapped Apple ProRes provides a flexible new format for broadcast delivery
• MXF master file export uses audio roles to configure industry-standard channel layouts
• Support for Canon Log2/Cinema Gamut and Panasonic V-Log
• Support for Sony XAVC-L at 4K for the Sony PXW-FS7 and PXW-X70 cameras
• Playback support for Panasonic AVC-Intra LT
• Export AVC-Intra files
Additional Features
• Flow transition seamlessly merges jump cuts to remove pauses or mistakes in on-camera interviews
• Remove Effects and Remove Attributes commands let you delete specific effects from clips
• SMB 3 network support enables library access on network-attached storage devices
• Timecode effect displays clip name and source clip timecode in the Viewer and in exported files
• Copy and paste timecode to speed up numerical entry from text documents
• Consolidate custom Motion projects into individual Final Cut Pro libraries
• Option for continuous playback of clips in the Browser
• Search custom metadata in the Browser and Timeline
• Search Timeline Index for Auditions, Compound clips, Multicam clips, and Synchronized clips
• Ability to roll trim on adjacent anchored clips
• Larger Media and Content browsers provide more space for viewing photo libraries, sound effects, music, titles, and generators
• Skim and select ranges of audio files in the Music and Sound Effects browser
• Use a Thunderbolt cable for direct A/V output to an external display, without the need for a separate I/O device
• XML 1.6 supports role-based audio components for Magnetic Timeline 2
• Enhanced XML support lets you import projects and clips into existing events
• Ability to drag and drop clips, projects, and events as XML with supported applications
Compatibility: OS X 10.11.4 or later, 64-bit processor
Download From NitroFlare
http://nitroflare.com/view/7B383E2D01F6073/Cut_10.3.part1.rar
http://nitroflare.com/view/F667F7DA5E0627C/Cut_10.3.part2.rar
http://nitroflare.com/view/0ED5BEF3D0342B0/Cut_10.3.part3.rar
Download From Rapidgator
http://rapidgator.net/file/74ea4aed7df3c1493028bc985f168067/Cut_10.3.part1.rar.html
http://rapidgator.net/file/555aa551b96738a6d708b4bbeaf24028/Cut_10.3.part2.rar.html
http://rapidgator.net/file/159aab71fa91417e8feba8bd29320e92/Cut_10.3.part3.rar.html
Download From Keep2share
http://k2s.cc/file/be3c0739d6334/Cut_10.3.part1.rar
http://k2s.cc/file/a3365bf748b1a/Cut_10.3.part2.rar
http://k2s.cc/file/9567cf740aa6c/Cut_10.3.part3.rar
