ExamXML Pro 5.50 Build 1080 (x86x64)
ExamXML Pro 5.50 Build 1080 (x86/x64) | 3 Mb
ExamXML is a powerful and easy to use a visual XML differencing tool for Windows. It was specially developed for comparing and merging XML files in an intelligent manner. It provides best-in-class features that distinguish ExamXML from other XML differencing tools. Unique to ExamXML is its ability to ignore elements that match users' defined condition. In addition to the usual textual comparison, ExamXML adds ability to compare numbers in numeric format and dates in date / time formats.
ExamXML is a powerful and easy to use a visual XML differencing tool for Windows. It was specially developed for comparing and merging XML files in an intelligent manner. It provides best-in-class features that distinguish ExamXML from other XML differencing tools. Unique to ExamXML is its ability to ignore elements that match users' defined condition. In addition to the usual textual comparison, ExamXML adds ability to compare numbers in numeric format and dates in date / time formats. ExamXML displays XML documents in a tree view, highlighting differences down to the level of elements, words or attributes, so that you can view exactly which attributes and elements have been added, modified or deleted. Red color means that the element has been removed, green means that the element has been changed.
» Visual displays XML documents in an interactive XML TreeView
» Easy navigation through the differences
» Validates XML documents against DTD/XML Schema
» Extensive comparison options, for ignoring capitalization, white space, elements order
» Normalization of dates and numeric fields
» Saves the differences and/or similarities to output XML file
» Advanced ignoring XML elements
» Smart comparison using Key elements or Key attributes
» Imports from Excel (CSV) and Export to Excel (CSV)
» Imports database content from SQL servers to XML format
» Displays only different elements
» Drag and drop support
» Command line operation
Home Page -
http://www.a7soft.com/examxml.html
http://rapidgator.net/file/69456c4d988adbe789891f5232c8451f/xpr9z.ExamXML.Pro.5.50.Build.1080.x86x64.rar.html
http://nitroflare.com/view/CAE6B282BDC6143/xpr9z.ExamXML.Pro.5.50.Build.1080.x86x64.rar
