Combo Cleaner Antivirus Premium 1.1.5
Combo Cleaner Antivirus Premium 1.1.5 | macOS | 5 mb
Your Mac is a masterpiece - keep it this way with Combo Cleaner. The most easy-to-use way to clean your Mac from junk files, viruses and malware. Our Anti-Malware engine is certified by OPSWAT Labs. Combo Cleaner will clean your disk of junk files and eliminate malware (including adware and potentially unwanted applications causing unwanted ads when browsing the Internet).
Combo Cleaner features:
• ANTIVIRUS - Combo Cleaner is equipped with an OPSWAT certified, award winning virus, malware, and adware scan engines. Hourly malware definition updates ensures that your Mac will be protected from the latest security threats.
• DUPLICATE FILE FINDER - Duplicate files are identical copies stored in various places on your hard drive. Combo Cleaner will find and eliminate these files that are a waste of valuable disk space.
• DISK CLEANER - Disk Cleaner ensures that your Mac is free of junk and obsolete files that can accumulate megabytes of wasted disk space.
• BIG FILES FINDER - Big Files Finder checks your local and external disks, immediately listing all files and folders larger than 100 megabytes (or any other user defined size).
• APP UNINSTALLER - When you remove applications from your Mac, many useless redundant files often remain on the system. Combo Cleaner will find such files and remove them.
• PRIVACY SCANNER - Scans installed browsers and enables you to easily remove stored browsing history, cookies, etc. Take privacy into your own hands.
OS X 10.10 or later 64-bit
https://uploadgig.com/file/download/9c6474e2E2eCf570/tlepXoYN_Combo_Cleaner_Antivirus_Premium_1.1.5_MAS_InApp_TNT.rar
http://nitroflare.com/view/5E7A4AAE3CCFE55/tlepXoYN_Combo_Cleaner_Antivirus_Premium_1.1.5_MAS_InApp_TNT.rar
https://rapidgator.net/file/cd50f1bbd340934663887cd14d982add/tlepXoYN_Combo_Cleaner_Antivirus_Premium_1.1.5_MAS_InApp_TNT.rar.html
http://turbobit.net/5yqa1b8r9q44/tlepXoYN_Combo_Cleaner_Antivirus_Premium_1.1.5_MAS_InApp_TNT.rar.html
