ACDSee Pro 10.0 Build 625 (x86x64)
Loaded with everything you need to bring out the best in your images, ACDSee Pro 10 gives you effortless digital asset management and hundreds of non-destructive adjustments for the enhancement and control of your image production. Blaze through all of the essential tasks of your photography workflow with this solid, GPU-enriched member of the ACDSee family.
Here is just a small taste of some of our best-loved features...
* Develop Mode
Perform a wide range of parametric adjustments in Develop mode, specifically designed as a RAW conversion environment, allowing you to create instructions for adjustments, rather than adjusting the pixels themselves. Work on RAW, JPEG, and other image formats.
* Pixel Targeting
Selectively adjust pixels with a variety of Edit mode tools by targeting specific colors and tones within the image. Even target skin tones!
* Automate Your Adjustments
While Batch Edit only contains a handful of adjustments, you can use ACDSee Actions to record and batch-apply any of Edit mode's 200+ adjustments.
* Chronicle Your Process
As you make adjustments, take snapshots at any time to save your work up to that point. Continue to edit as desired, but return to the version in your snapshot at any time.
* Extended Editing Capabilities with Photoshop™ Plugin Support
Expand your creative scope with the ability to import and apply Photoshop™ plugins to your Edit mode adjustment workflow. Draw your own effects and use them in combination with best-in-class photo editing tools.
* Your Instant Start
Connect directly to the folders on your computer - no importing into a separate library. Enjoy increased speed and performance by organizing and cataloging your photos as you get them from your device.
* No Aimless Searching
Find images based on metadata, file properties, date, event, keyword, rating, color label, and GPS location. Build and save detailed searches, enter single words or phrases, search only specific folders, or find that one particular image with the Quick Search bar.
* Organize for the Win
Add ratings, hierarchical keywords, categories, and location data to your images. Quickly identify photos for further processing with visual tags or customizable color labels.
* Distortion Doctoring with Lens Correction
Correct barrel and pincushion distortion in your photos by applying the correction calibrated to fix the distortion inherent to the lens used - even fixing chromatic aberration. Map this correction to your lens and it's set to correct every time.
* Take Your Lighting out of the Dark Ages
Get HDR results by intelligently adjusting areas that are too light or too dark. Powered by our patented lighting technology, you can instantly lighten shadows and reduce highlights in one click.
More Improved Features:
* Improved stabilitys
* Updated lens correction profiles
* Improved lens detection
* Beefed up speed and performance, with GPU-enhanced Develop mode
x86
x64
http://rapidgator.net/file/5f366da7eaba53d42066d0d5534de361/6g3vg.acdseepro10.rar.html
http://rapidgator.net/file/35d3114715e179474fc7b7403f5acef4/6g3vg.acdseepro10x64.rar.html
http://nitroflare.com/view/2619E977E5BB192/6g3vg.acdseepro10.rar
http://nitroflare.com/view/259C75C1414C0EA/6g3vg.acdseepro10x64.rar
http://uploaded.net/file/bbokzr6a/6g3vg.acdseepro10.rar
http://uploaded.net/file/2b4c9vpw/6g3vg.acdseepro10x64.rar
